Scornio
Ok so there is a way to disable it...Soo how do you do that? LolYou could just disable the rear o2 sensor via the flashpro if you just want the light gone
Open the calibration tab.... then click on closed loop..... and then uncheck "secondary O2 sensor enabled"Ok so there is a way to disable it...Soo how do you do that? Lol
Omg I feel like such a noob lol thanks I appreciate it!Open the calibration tab.... then click on closed loop..... and then uncheck "secondary O2 sensor enabled"
how did the tune go bro? i was in the same boat as you, i did a general tune, then after having all the bolt ons, i decided to start my VITtune, altho im only a few flashes into my tune, there is definitely a difference with the tune from VIT. even tho i only have an R18, i feel its definitely worth it with my econobox. a little more power and still great gas mileage.
Thanks for your info. I hope someone can answer the running rich question.The reflash is the one you want. The other one is if you are returning to car to stock. Don't know about it running rich with the reflash though.
I will say the reflash map is okay, I wasnt completely satisfied with it when I used it initially. It worked for the short period of time while I was waiting for my bolt on to come in, however I would recommend a custom tune, even if it is stock, to get the most out of the flashpro. If youre waiting for parts, it works in the meantime, but I was not too thrilled with how it ran with the reflash tune. But thats just my opinion.
You can load the calibration and datalog the afr to see for yourself how the car is running. You can also view fuel trims to see how much adjustment is being applied, you want to see +/-5 on the short term trimsThanks for your info. I hope someone can answer the running rich question.
