0260N5Si
I need to upgrade my rotors and pads to something decent (but nothing drastically expensive)
What do you guys recommend?
What do you NOT recommend?
What depth is your tint? 50%?Depends if youre tracking or not. Thinking to upgrade the calipers too?
No I'm going to leave the calipers as they are covered by warranty.
If you are going to track your car I would consider upgrading the pads otherwise you will get a lot of brake fade when they heat up after a few laps.Blank rotors will give you the best performance over slotted or drilled.
A more aggressive pad compound will give you more initial bite but the limit of how hard you can hit your brakes is limited by your tires. You should be able to lock up the wheels on the stock pads/rotors just fine. The ABS will kick in before that happens though.
I ran the Hawk HPS for a while. Not a bad pad. If you're not doing auto-x or hitting track days the OEM pads are a really decent balance of performance, noise, and dust. A more aggressive pad will give you more braking "force" but at the expense of either noise/dust or both.
I'm currently on PBR/AXXIS Ultimates and they are way better at stopping. Especially under extreme conditions and heat. However, they are an insanely dusty, dirty pad. You will need to clean your wheels constantly.
