Michal006
I did that when I first got my Si but what's the shift point to get 0-60 in 6.1 sec.. Is it Vtec Vtec Vtec Vtec
Good launch with traction control off and shift at redline.
the Si jumps out in a race but what gear to maintain your lead in a 0-100 race?Good launch with traction control off and shift at redline.
0-100mph?
Start at 2000rpm. Seriously. At least for a 2012 it's the best you can do without actual launch control. Just back off the throttle a touch so you don't chirp and spin too much, unless that's your goal.
As others have mentioned, shift at redline. (personal preference is slightly different, like shifting slightly 'pre-redline' into 2nd and 3rd. You never want to hit fuel cut-off, tho one solution is to raise redline to 7,600, which is still reasonable) OR F-it, eliminate redline and live like a man!
Anyway, if only going 100mph 4th gear will get you there. 3rd gear will take you to 77mph and after an easy drop to 4th you'll be done in a matter of seconds. Then you're on to the next stop light.
But it's such a shame to stop there. 5th gear feels perfect around 125. Unfortunately most stop lights are too close together for that.
Ever thought about joining a bunch of maniacs (and one joker) at The Dragon?
0-100mph?
_________________...except when you're at 69 mph and go to grab 4th and pop it back into 2nd. Tap that tach needle on the dash. That'll wake you up for sure. Might need to change your shorts and perhaps other things too that aren't so cheap.
_________________
_________________________
Noticed you haven't committed to the Dragon yet. You're thinking about it, right?
Lol I will check the info
_______________If you shift using the shift points specified, that's usually around 4000-4500 rpm and lands you in the 3000 rpm range. That's not horribly conservative and it's not overly aggressive.
