phil136
After installing my H&R springs over a month a go I started getting a popping noise on the front passenger side as i turn the wheel while parked or turning the wheel while doing really slow turns, 3 point, parking spaces, etc.
It a sequence of 3 pops turning the wheel in either direction, separated by several turns of the steering wheel. Its a very distinct pop that sounds like the spring under tension getting released after going an uneven surface and the popping against metal after clearing that uneven surface .
i have read that can happen when the top hats are not installed correctly.(arrow point to the front of the car)
So I installed the new shocks/struts yesterday and was gonna check what could be the problem. of course my top hats were pointing in all diff directions(LOL). I made sure that they were in correctly this time. I also inspected the springs. I noticed that the passenger side spring had way more rubbing wear between the coils. I threw on some grease between the coils just for the heck of it.
After all was done. same damn noise. Its not that big of a deal but i would really like to solve this. Perhaps there was damage to the top hats after wrong install. Although visually I couldn't see anything wrong. Im starting to think there's something wrong with spring.
IM gonna recheck all the bolts are torqued to spec as I dint have time last time.
