Just a heads up... One should NEVER put an amp cable any where near through the door where it opens and closes. Amps cables should ALWAYS be run through the firewall and down inside the car or down the molding internally through the back seat.
There is a huge risk of pinching a cable when the door opens and starting a fire eventually. I will fire an employee if they run the install through a door... or from the looks of these pics through where the door opens and closes.
Just a FYI... always always always go through a firewall for your OWN SAFETY!!! In an EX or EXL model you can typically use the clutch hole because there is no clutch. Otherwise you can generally fish it through a grommet in the front. I'll take a picture where I fished mine through!
