Monk
So what's your reasoning that increasing the frt will slow it down TTC's.? I'd like some tech reason if you can explain it. Frt wheels drive is new to me.So much bad info on the internet. Bottom line is this... increase size of rear sway bar from stock and it will make the car faster through corners (handle better). If you increase front and rear from stock, it will make the car corner flatter but not necessary improve it's speed through the corner.
So, if you want a better handling and make your Civic faster through corners, increase the rear but do NOT increase the front. Anyone who says you should increase the front better give me a very good reason why other than to keep the tire's contact patch on the ground because that's cutting off your nose to spite your face.
Now if it's a RWD car, that's different.... but the Civic ain't that.
Chris
