Dar-Dar
Mordorator
- 19,329
- 9,901
- Vehicle Model
- Civic Si
- Body Style
- Fiji Blue Pearl Coupe Coolest Member Since: May 15, 2011
Okay, I may do that. Depends on how rushed I am and how frustrating the spring install is. I'm using 8th gen springs (H&R OESport only avail. for 8th gen) according to the DIY I saw online, and I do not plan on using compressors. I have done it this way before, where I just unscrew the nut on the top-hat before removing anything else. Then using a floor jack to compress the spring to reinstall the nut while reassembling
It will be easier to remove the rear springs using a spring compressor bc you wouldn't need to remove the sway bar end links.
