PistolPete
I've got a 2012 SI coupe and want to pick up a set of summer tires and wheels when my wife will allow.
The stock tire is 215mm wide, so running something that is 225mm wide should fit for sure. But anyone running something wider, like a 245mm tire? If so are you getting any rubbing? What wheels and offsets are you using?
Thanks in advance!
Thanks in advance!
