Cadillac ATS makes it's debut around 'Ring
22,314
if you watch the video closely, you'll even catch a glimpse of the euro civic on the ring
Prototypes have been a lot more visible of late, and the future entry-level Cadillac appears to be spending a lot of its time over in Germany. Here is a video of the well-camo'd Caddy as it runs the famed Nürburgring – in a big, fat hurry.
If you listen hard enough, you can hear some high-revving engine notes, but with the screaming tires it's anyone's guess as to what's lying in wait under the bonnet.
NAFG2_KDMFTW
77
Tampa Bay
So is this supposed to replace the CTS? Or is Cadillac just adding a new, similar model to their lineup? Definitely doesn't look large enough to be an STS replacement. I'm lost.
  • Thread starter
  • #7
22,314
supposedly the little brother to the cts.
an earlier article -
The big news powertrain-wise is that the ATS will get a turbocharged four-cylinder. The entry-level ATS is slated to come equipped with a 270 horsepower version of GM’s turbocharged 2.0L engine, backed by an eight-speed automatic transmission. Thanks to those eight cogs, the 2.0 ATS should return 22/32mpg.
An up-level 3.6L model will also be available, boasting 330 horsepower and 280 lb-ft of torque. It too will be mated with an eight-speed gearbox, returning economy of 20/30mpg.
An ATS-V model is certainly possible, but it remains to be seen what engine what stuff between its fenders.
Dar-Dar
Mordorator
19,329
9,900
North NJ
22/32 is really good for a car with 270hp weighing over 3000lbs.
