detachable wheel/hub?
PhillySunburstFG4
69
hey guys,
just wondering if any of you guys had a detachable wheel on your 9th gens and if so if there was a SRS light on after the install? Was thinking about installing one on mine if there are no issues after the install. Thanks!
Nix
Jötunn Moderator
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
You would probably get one since the airbag is being removed. I know that on the previous gen if you removed an airbag or had an SRS light on that it would deactivate the rest of the airbags as well. Pretty dangerous. I am unsure of how the 9th gen may respond in a similar situation. I don't know if this is something hondata/flashpro could override.
What wheel are you looking at? Any particular reason you want the quick release hub option?
I have seen a couple places that do custom inserts to the stock steering wheel so you can have say a carbon insert between 10 - 2 on the wheel.
PhillySunburstFG4
69
Ah gotcha man thanks. Just wanted to switch it up. Get rid of all the buttons on the wheel cause I don't use them anyway lol. And it's a decent security feature as well which is also another reason I'd like one. My neighborhood is going down the drain.
22,314
