Since I've had my si my dome lights don't turn on, I've pulled the fuse, which isn't burnt out. And I've checked the bulbs, which are also not burnt out. Not sure why the dome lights won't turn on. Any thoughts?
Just guessing here. There must be some sort of sensor in the door which connects and disconnects the circuit. I.E. Door is closed circuit is disconnected, door is open circuit is complete and lights go on. Perhaps the problem is with a door sensor not working properly. I don't think that would be it though because the lights should work when any other door is open.
The only other thing I can think of is the light switch. Is it in the correct position? Does the light work when you turn it on manually?
