SpikedJoker
A few months ago I installed a skunk 2 cold air intake on my 12 Si . To do so, it requires relocating the battery, and extending through splicing a few wires. They give you a new battery tray and all the items needed. However after doing so the I mid shut off and the car didn't want to start. It was a blown fuse and ho day had to extend and relocate the negative cable again. A few weeks go by and the yellow top I bought to build my sound off of died. I had it tested and they said it was a bad battery, got it replaced but it didn't fix the problem. The I mid and now the stereo go off and on at times and I can't figure out why. While running the car stutters o ce or twice at idle and acts like it's not getting charged but doesn't die... also while driving the head unit goes off, I mean black like the cars off. I've checked all the wires and I couldn't find any cuts or loose connections, so I'm at a loss.
