Scotty1981
I wanted to find some good speakers that won't be underpowered by the factory HU I don't really want to mess with an amp at this time.
I've heard the sound out of the alpine power pack amp. It's a small amp to get better sound when replacing the factory speakers. And he got it installed behind the dash. http://www.crutchfield.com/p_500KTP445U/Alpine-KTP-445U-Power-Pack.html
I'd like to keep them in the same locations though.Yeah those go to the HU, but most likely a new HU will have both
Definitely Alpine's powerpack unit isn't going to be the best solution. That all depends on your budget and what you are committed to achieving. The powerpack works only b/c its a cheaper alternative w/ line level inputs and can run on the HU power from the car. The signal processing is gonna be weak in that unit, but better than stock. But I agree w/ hotshot, if you want it done right w/ your HU. Separate signal processor, separate amps and power is your best solution.I dunno about that alpine powerpack. I think the best route to take if youre wanting to keep the factory headunit would be something like a JL cleansweep or a Rockford Fosgate 3sixty or something like that. a stand alone signal processor, and then sticking in a separate amp, but It's more time consuming, and more expensive, but its the best way.
