taxidriver1138
Active Member
- 6
- 0
- Vehicle Model
- Civic Si
- Body Style
- Sedan
I just got a 2014 Civic Si, but my amplifier can't accept differential outputs and I don't feel like buying a new amp so I'm thinking of getting an AudioControl LC7i and setting it for channel summing. I need advice on how to connect it. From my understanding (correct me if I'm wrong) the front speakers have the highs going to the tweeters and the rears speakers have the lows going to the factory subwoofer using the crossovers built in to the factory amplifier. So should I wire the tweeters, rear speakers, and factory sub to the LC7i or the front, rear, and factory sub? Also how should I connect the factory sub wires since its only one pair. Should I split the wires and connect them to the LC7i or should I just connect them to the left or right channels? Also if you have any other solution that might be easier than this I'm all ears.
