How to remove seized nut from loose stud
HeelsandEers
338
Motown, WV
FA5
22,314
the one mentions to put two nuts on the other end. You'd put a vise grip on the inside nut of the double side, and then a vise grip on the nut at the other end. If you just did 1 nut on the end, I'd imagine it'd just spin trying to remove the other side. The 2nd bolt snugged on the 1st should help
HeelsandEers
338
Motown, WV
FA5
See, now that makes sense. Thank you.
I'll see about picking up another nut when I have to go to the hardware store tomorrow, otherwise I'm just gonna thread it into the head as is. It should work the same that way.
