Passenger door power windows not working; not switch issue
Is it...
  • A wiring issue
    Votes: 0 0.0%
  • A mechanical issue
    Votes: 0 0.0%
  • Still convinced its the power switch module
    Votes: 0 0.0%
  • A programming issue?
    Votes: 0 0.0%
  • Something Else
    Votes: 0 0.0%
  • Total voters
    0
Daniel Joung
New Member
1
0
2013 Honda Civic. 99k miles, 1st and only owner.
Both Driver and Passenger side Power window switches stopped working.
Driver side switch started working again after I replaced the power window switch module (ordered online).
The lock/unlock switch works fine and did not need replacing.
Then I replaced the passenger side power switch with a new one, but it did not fix the issue. Nothing happens when I press up/down on the passenger side switch. Additionally, nothing happens when I press up/down for the passenger window FROM the drivers side switch. But all the other windows work properly when controlled from the drivers side switch.
Lastly the lock/unlock switch on the passenger side also behaves erratically. It won't lock, but will attempt to keep unlocking if I press unlock (I can hear the mechanical sound)
I am planning on opening up the door panel. Please let me know if you have any advice on what to do or expect.
My theories are listed in the following poll:
