Rebuilding crashed civic! Need help
Patrik
Active Member
10
1
Los Angeles ca
Civic ex
I got in a car accident and only have liability on my 2013 civic. I want to rebuild the car because it still runs. From what I know just the radiator is the only mechanical thing that got damaged. I definitely need a new one. What should I get started with? What part should I order first?
Sarcras
702
North Dakota
FB6
Have you had it inspected for any other damage that might not be obvious? Like the frame or subframe damage.
22,314
This can't be serious. You have substantial damage to the whole front end of your car and engine bay. How do you plan to mount a radiator when the whole front is smashed? I wouldn't be surprised if you had 5-7 grand or more in damage there from just seeing the pic. Take it to a repair shop. They can print an invoice/quote on parts and labor from what they can visually see damaged.
Nix
Jötunn Moderator
10,765
8,162
Lew-vul, KY
It's A Fast Pig!
Wow, that looks like way more than just a "radiator". Dude that whole upper support is wrecked. So is the crash bar in the front. What sort of insurance do you have that they didn't total it out for you... ugh sounds like "The General" at work.
In any case, AHparts.com has a lot of OEM stuff off other wrecked cars. I bet you can get a ton of stuff from those guys. If they don't have it listed, just call them. They will pull any single clip, bolt, and panel that you need. They are located in CA and shipping should be very reasonable. I ordered over 200lbs of stuff from them to the East coast and it was very affordable. CHH has new OEM stuff but if you just need bits here and there, check AHparts.
Patrik
Active Member
10
1
Los Angeles ca
Civic ex
I have progressive. The insurance does not want to look at my car because I only have liability insurance so they said they won't check if it's totaled or not. So the damaged stopped at the radiator. Starter isn't touched, alternator is fine, belts are fine. It's just the frame and any exterior parts of the front are damaged.
Patrik
Active Member
10
1
Los Angeles ca
Civic ex
I was wondering what this part is called. I've been trying to look for it
Tak
388
New York City
LX
Sedan (FB2)
i suspect this car is totaled if it goes through the insurance. This appears to be a 8K+ repair and you have a civic ex. I think the insurance will write it off....
22,314
Liability insurance doesn't cover damage to your own car. It only covers damages you cause to someone you hit. Insurance won't do anything for his car.
shekki
30
Washington
Civic LX
The amount of damage on your car would definitely total it if you had comprehensive or collision coverage. I would definitely have a shop write up an estimate for you so you have a good idea on what parts you're going to expect to buy if you plan on repairing it yourself. Keep in mind that the estimate won't be all inclusive without a tear down and most shops won't do that without having you pay for a tear down and possibly to put it back together.
