davefootball123
- 3
Hi all, roughly 10 months ago, I had the clutch replaced on my 2012 Civic 1.8 as per Honda's recommendations. I didn't really notice anything wrong with the clutch other than Honda saying it would need replacing soon, roughly at 180,00 kilometres. There was a slight shudder on hot days when engaging the clutch. Iwent ahead and had the clutch replaced. Upon completion, there was a significant shudder engaging first gear this slowly subsided however it became intermittent, after highway driving it would be fine, sometimes would shudder etc. I took it back recently and then did the install again, still the same shudder. Completely new components including OEM clutch kit and flywheel each time. They don't think its the clutch and are potentially thinking its the lower torque mount.
Any ideas as to what else may be causing this? Any help would be great.
If thinking this may not be clutch related as if I have the e-brake engaged and do a normal start and the car doesn't move, there is no shudder but immediately upon releasing the e-brake it'll begin to shudder.
Thanks
Thanks
