Toyota recalls 52,000 Prius hybrids for steering defect
2fast4u2
382
Toyota is recalling 106,000 Prius models built between 2001 and 2003. A total of 52,000 of those units were sold in the States.
Toyota says that if the steering wheel is strongly turned to the full lock position over and over again, the electric power steering pinion shaft nuts may become loose. Over time, that may result in the driver having to exert more force than typically necessary to turn left.
Owners can expect to be notified of the recall in early July, and the repair (in which dealers will replace the electric power steering pinion shaft nuts with new equipment) is expected to take around four hours.
In addition, the Japanese automaker is recalling a handful of Venza and Sienna all-wheel drive models for improperly heat-treated front drive shafts. The recall covers a total of 34 Venza models and 16 Sienna units produced in 2011, and owners can expect to be notified of the problem by June of this year. Hit the jump for the full press blast.
