Bulb Sizes - Lamp Replacement Guide
Discussion in 'Lighting, HID's, And Retrofitting' started by jasonandre, Nov 24, 2012.
  1. AlienPrime
    AlienPrime Well-Known Member
    3,058
    Sudbury, Ontario, Canada
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    7443 = T20
    7440 = T20
    168 = T10
    194 = T10
    DE3175 = 31mm Festoon
    If your trying to be technical, DE3175 can be a 41mm festoon too.
    The only reason you see different values is because they are different bulbs. If your swapping with LED's wattage is different anyways.
  2. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    [​IMG]
    Backup lights are all T20
  3. Jonathong
    Jonathong Well-Known Member
    388
    Delano, California
    Vehicle Model:
    Civic SI
    Body Style:
    thinking about replacing my drl/high beams to yellow nokya ones. Quick question though whats the stock wattage on the oem bulbs? The one nokya lists is that they are 65w and my only concern is will it get to hot and melt the plastic around the bulb or mess up the wiring? Any info is greatly appreciated.
  4. TheSlowAndTheSerious
    TheSlowAndTheSerious Well-Known Member
    1,764
    New Jersey
    Vehicle Model:
    Body Style:
    65w is fine dude, stock I BELIEVE is 35w.
  5. webby
    • 2019 Toys For Tots
    webby Administrator
    50,620
    you're going to run yellow high beams?
  6. Jonathong
    388
    Delano, California
    Vehicle Model:
    Civic SI
    Body Style:
    Well I hardly use my high beams but isn't the drl the same bulb used when we turn our high beams on?
  7. webby
    webby Administrator
    50,620
    that's correct
  8. Pauly99to17
    Pauly99to17 Well-Known Member
    9,171
    Ville de Quebec
    Vehicle Model:
    2012 LX
    Body Style:
    Dyno Blue Pearl Sedan (FB2)
    I have the Spyder fog lights which have bulbs already in them, but they are not the best quality. I'm looking for h11 bulbs that are LED and are as bright as possible. I don't want to go HID route, don't need to be that bright. I would like them to be white with a blue tint to them.
    I found these, but am wondering what the differences are. Are the different numbers referring to brightness. Are there ant over heating potential dangers if i get LED bulbs that are maxed out for brightness. I would assume not because they are LEDs, but want to have this confirmed. Thanks!
    http://www.shopwiki.com/l/Xenon-White-H11-LED-Bulbs,-H11-LED-Fog-Lights,-H8-LED-Fog-Lights
  9. webby
    webby Administrator
    50,620
    Pauly99to17 likes this.
  10. chrisman3063
    chrisman3063 Member
    3
    Anyone know what size the front turn signal bulb is for the uae headlights?
  11. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    H11
  12. DonDeeBoogie
    DonDeeBoogie Well-Known Member
    46
    Brooklyn, NY
    Vehicle Model:
    Civic EX
    Body Style:
    Ok.. i looked around and I know this is such a novice question... but how do i change the low beam bulb in a 2013 coupe? don't think I can stick my hand in there.
  13. webby
    webby Administrator
    50,620
    DonDeeBoogie likes this.
  14. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    if you have to change the signal bolbs you're better off to remove the headlight. Otherwise, you can remove all the **** in the way and then you'll be able to reach em easy.
  15. DonDeeBoogie
    46
    Brooklyn, NY
    Vehicle Model:
    Civic EX
    Body Style:
  16. DonDeeBoogie
    46
    Brooklyn, NY
    Vehicle Model:
    Civic EX
    Body Style:
    Thx @AlienPrime, I'm just changing the low and hi beams. Just picked up some yellow Nokya's for DRL/Hi and PIAA's for lows. Did the hi's and they look sweet..me likes..lol.
    Just couldnt figure how the Efff i was going to stick my hand in there to change the low's.
  17. AlienPrime
    3,058
    Vehicle Model:
    Civic Si HFP
    Body Style:
    2 door Coupe
    take out the battery on one side and take out the washerfluid pour drain one other
  18. PMMcivicFB2
    PMMcivicFB2 Well-Known Member
    772
    Canada B-Town
    Vehicle Model:
    Touring
    Body Style:
  19. spicy
    spicy Well-Known Member
    329
    If I'm not mistaken the 2014 Sedan Fogs are H8 now, no?
    PMMcivicFB2 likes this.
  20. parabolapk
    parabolapk New Member
    1
    H
Share This Page
