DIY Clutch Delay valve Removal
Discussion in 'Engine DIY' started by Mikex18, Aug 11, 2013.
  1. bauer311
    • Supporting Member
    bauer311 Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    Has anyone attempted this without taking the assembly out of the car? Is there any reason you need to other than a possible space issue? Just don't have anyone to help bleed the clutch, so if I can do it without removing it would be a big help to me...
  2. squiggy
    squiggy Cartographer
    10,922
    Michiana
    Vehicle Model:
    '12 Civic Si
    Body Style:
    DBP II Coupe
    No way in hell you are getting the C clip out without taking the assembly out of the car. Order a speed bleeder so you can bleed the clutch yourself.
    JonnyRotten and Sarcras like this.
  3. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    Damn...guess this project will have to wait until I get back. Got a question about this picture though. This is my cdv, right? How do I disconnect the two pieces to even get the cdv off? Don't wanna break anything.
  4. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    [​IMG]
    Sorry, this was the picture I was referencing above.
  5. dpetro1
    dpetro1 Well-Known Member
    414
    Catonsville, MD
    those two pieces are not attached to each other. you will see once you remove the bolts. the slave cylinder pushes out on the release fork when you shift.
    bauer311 likes this.
  6. ron v
    • 2019 Toys For Tots
    ron v The good, the bad, and the booty
    3,911
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    Cdv is on the very right of that pic. Those 2 bolts hold the sc on I'm thinking. once u get in there with more room it'll make sense to u.
  7. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    Thanks @dpetro1 and @ron v. Just wanted to make sure I'm not trying **** up. May get after this after all, doesn't seem too complicated. Now I gotta find a speed bleeder....prolly got them at pep boys or something.
  8. dpetro1
    414
    Catonsville, MD
    should be m8x1.25 on the bleeder
  9. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    So, I was being stubborn and took the valve body apart only to discover there's no c clip, white thing or black thing like the pics at the beginning of the build thread show. I was able to pull out the "cylinder" and behind it was a spring, that's it. Are maybe the ex's different than the si's?
    ron v likes this.
  10. zrksi
    zrksi Well-Known Member
    22
    Bro I remember reading in a thread that the CDV for non-si's are located in the master cylinder, not the slave. It's not the same. I'll try to find the post, but its not in the same location
    PainlessCandy likes this.
  11. zrksi
    22
    found it
    Posted by another member on page 13
    If the '12 EX is similar to the '12 Fit, they included the CDV inside the Clutch Master Cylinder (not in a separate slave cylinder like the Si). If this is the case, the only way to do the CDV delete is to replace the entire CMC with one that does not have a CDV inside, like from an older model Civic. I personally have not seen anyone try to do the CDV delete in anything but an Si, but here is a Fit forum thread where they had to replace the entire CMC. Doesn't look too difficult, just a matter of finding the right replacement parts.
    http://www.fitfreak.net/forums/fit-diy-repair-maintenance/76598-clutch-delay-valve-delete-diy.html
    ron v and dpetro1 like this.
  12. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    Thanks for the info brotha. Guess I can skip those plans for a while, lol
  13. ron v
    3,911
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    My lil cousin came into town and begged and pleaded for me to do his. Funny. This one took me less then an hour start to finish.
    PainlessCandy and JonnyRotten like this.
  14. mazda_lexus
    mazda_lexus Well-Known Member
    204
    Myyy turrrrnnnnnnnnnnnnn
    ron v likes this.
  15. bauer311
    • Supporting Member
    2,583
    Fayetteville, NC
    Vehicle Model:
    civic ex
    Body Style:
    coupe
    The experience from doing yours must have sped up the process @ ron v
  16. ron v
    3,911
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    I'm leaving town next weekend but I can probably do it Friday afternoon like 330-4. Besides that I won't be able to do it for a while. U come up here too. I'm not battling that traffic. Lol.
    And a disclaimer. I'm not a master certified pro mechanic nor do I claim to be. I just like to work on cars. So with that in mind, let me know.
    mazda_lexus likes this.
  17. ron v
    3,911
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    I think I have an extra speed bleeder too
  18. mazda_lexus
    204
    When'll you be available next? I probably can do Friday. Where are you located
  19. JonnyRotten
    JonnyRotten Well-Known Member
    1,673
    Mississauga, Ontario, Canada
    Vehicle Model:
    Body Style:
    coupe
    I just placed my order with Speed Bleeder for the F/R brakes and the master cylinder.
    Thanks @jsyn77 for the part numbers.
  20. JonnyRotten
    1,673
    Vehicle Model:
    Body Style:
    coupe
    Can someone please confirm the sizes of the Speed Bleeders for our cars.
    I ordered a bunch of Speed Bleeders based on the info @jsyn77 posted and it's wrong :mad:
    I'm thinking that @trustdestruction has the proper information because it looks like he did some research.
    The part numbers in @jsyn77 post are definitely wrong.
    I need to know the sizes for both the front and rear brake callipers and the clutch slave cylinder.
    I don't want to get into these projects only to find out that I have the wrong bleeders and make a whole bunch more work for myself unnecessarily.
    @webby can you help?
Share This Page
