Mike's boosted build
Discussion in 'Build Threads' started by mySIck, Aug 20, 2015.
  1. sunofwolf
    sunofwolf Well-Known Member
    1,539
    Vehicle Model:
    honda SI 2013 35% tinted Hondata coupe! Igore my post. SRT-4 modded race car! VFR-800-11750 rpm! Neon 2001!
    Body Style:
    coupe
    :confuzzled:
    I don't know if 7800rpm is safe or not, seeing how I only have one K24engine set redline to 6800 that way I know it won't blow up. I want a million mile engine. The funny thing do you really ever know if its safely turned what happens if a fly gets in and lick's the ECU that might throw it off then bomb K24:woowoo:or it goes lean that's very bad for a alu block. You can get away with a bit of lean on a 63 mitsu engine even though that can blow too. A k24 engine is very expensive like $3700 I see.:think::iough:You never use a power sander on your headlights too much friction. Its only plastic. I guess you found out the hard way. Oh well back to drawing board. I do a thought experiment -Einstein.
  2. mySIck
    • 2019 Toys For Tots
    mySIck Well-Known Member
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    You can get a complete long block K24Z3 with around 40-60k miles for $350 I have already been there done that. I have complete faith in my tuner from
    https://www.prayoontoracing.com/
    I didn't use a belt sander I used products provided by the company and used as the directions suggested. Normally I just buy new housing's but this time I thought I should give it a try worst case I would make a mistake and learn from it just like I did. What I did was when I was sanding near the bottom i was not holding the drill flush causing it to dig with the corner of the wheel.
  3. sunofwolf
    1,539
    Vehicle Model:
    Body Style:
    coupe
    when you get a used engine-that's what you get and don't know how good it is but at that price you could go though them and find a good one. I am just kidding about the 7800rpm, but I don't think I want to go over redline just don't see the need too>:brock:
  4. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Mine came with a 1 year 12,000 mile warranty and I do agree you never know what you are going to get when buying used motor's.
    For the most part I don't drive my car hard but every now and then I enjoy going into boost or going to the track.
  5. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby do you know much about car audio? I bought new speakers and a rear sub. I got the JBL GX600C component speakers for the front and rear and I got the Kicker compR for the sub.
    The problem I am having is the front dosen't sound to bad but the rear sounds like the volume is low. I checked the wires to assure they are correct to my best ability. The next thing I thought was maybe the factory amp can't support the speakers?
  6. webby
    webby Administrator
    50,572
    did you just swap out the old speakers and hooked up the new ones to the original wiring and whatnot? Is the sub the 8" compR....does it fit in the rear deck without interfering with the truck braces? Or how did you hook stuff up?
  7. webby
    webby Administrator
    50,572
    also, any idea what the oem subwoofer is rated for in ohms? I don't know what it is rated. The oem amp from honda is rated for 4 ohms. It looks like the front/rear speakers you got are 2.3 ohms instead of 4 ohms if I'm looking at the right speaker?
    https://www.crutchfield.com/S-W8tweVrBIfu/p_109GX600C/JBL-GX600C.html
    and the compR looks like it can come in 4 or 2 ohm if I'm looking at the right one....
    I know some people had issues with running 2 ohm speakers on the stock amp from the 8th gen. I guess it could make the oem amp heat up too much....
    @squiggy posted this info from the stock amp sticker (4ohms)
    360 watts peak, 120 rms for the entire 7 speaker system...
  8. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I hooked up my speakers to the factory wiring. The rear sub was a tight fit I used the directions to wire the sub in a 4 ohm series. The front speakers alone are a peak of 270 watts and the rear sub is max 600 watts.
  9. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    And that is correct the speakers I got are rated for 2.3 ohms
  10. webby
    webby Administrator
    50,572
    I don’t know if the others being 2.3 ohm would be enough to cause the volume difference or not. I just know some on the 8th gen said their stock amps could overheat. I’d shoot crutchfield an email or call and just see what they say?
    mySIck likes this.
  11. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I sent them an email I should here something back within the next 48 hours.
    webby likes this.
  12. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
  13. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby questions about FlashPro manager. I was enabling my Secondary O2 sensor and noticed it had the red light/dot next to it. Do you happen to know what the red ones mean? I know when you make changes it will turn yellow or red.
  14. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I was wondering if it has a red DOT if it means it will not be enabled.
  15. webby
    webby Administrator
    50,572
    Yeah, so if you edit the parameter it turns red. Yellow means you edited it in the previous editing session
    From their support site:
    ruddyrid and mySIck like this.
  16. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Ah ok thanks!! I knew they had it on there website but for some reason I could not find it. I probably overlooked it 10x.
    webby likes this.
  17. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Got a couple goodies today
  18. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Moving out soon and trying to sell some parts. The wife is not happy at all with the kitchen .
  19. ron v
    ron v The good, the bad, and the booty
    4,167
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    All stock parts?
  20. mySIck
    1,749
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Yep, I do have a Full-Race catless downpipe.
    I also have a small Mitsubishi turbo.
    bauer311 likes this.
Share This Page
