Mike's boosted build
Discussion in 'Build Threads' started by mySIck, Aug 20, 2015.
  1. ron v
    • 2019 Toys For Tots
    ron v The good, the bad, and the booty
    4,207
    Escondido
    Vehicle Model:
    Hot fuego
    Body Style:
    Landscaper Truck
    So jelly right now. That’s a prl kit right?
    mySIck likes this.
  2. mySIck
    mySIck Well-Known Member
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Yes sir, with the PT6262 ball bearing turbo.
    ron v likes this.
  3. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    webby and ron v like this.
  4. webby
    webby Administrator
    50,617
    I don't know if their kit has any type of UV protectant/sealant you put on last? If it doesn't, you may want to pick up some jet seal or something similar to block UV. Once you start "fixing" the light, it no longer has the outer film on the plastic lens to protect it from just yellowing again in say a year or whatever.
    Go to like 11:00 min if this link doesn't work.
    View: https://youtu.be/BGQEHhxXYoc?t=669
    a year + later
    View: https://www.youtube.com/watch?v=jNZZkPa_u1w
    mySIck likes this.
  5. sunofwolf
    sunofwolf Well-Known Member
    1,585
    Vehicle Model:
    King Mr. Ceasar honda SI 2013 35% tinted Hondata coupe. SRT-4 modded race car! VFR-800-11750 rpm! Neon 2001!
    Body Style:
    coupe
    Looks like you went over the 7000 is that good for car? I don't think, I usually hit 6000 rpm in the srt-4 -just pass inspection going to list it for sale.:paper::pianodance:
  6. webby
    webby Administrator
    50,617
    most tuners with hondata push the redline towards 7800 ish rpm from stock.
    mySIck likes this.
  7. bootyluvr
    • Supporting Member
    bootyluvr Supporting Member
    17,960
    Baltimore, MD
    Vehicle Model:
    2015 Honda Accord EX-L V6
    Why even reply to him?
    dpetro1 and webby like this.
  8. sunofwolf
    1,585
    Vehicle Model:
    Body Style:
    coupe
    Doesn't the HP stop going up at 6800 at least in the k24?:chopwood::corndance::dancing:
  9. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby I believe it has the UV protection in it. If not I'll hold off until i get some.
    @sunofwolf it is ok the rev the motor to 7,800 safely as long as it is tuned. With basic bolt on such as exhaust manifold, intake manifold, intake system, exhaust you can make power up to 7,500 and even with a good tune you can pull out power in the top end. Look at vittuned forum he has a lot of dyno runs also Derrick Robinson shows tons of dyno runs of K24.
    webby likes this.
  10. webby
    webby Administrator
    50,617
    mySIck likes this.
  11. webby
    webby Administrator
    50,617
    because maybe there's a chance the knowledge will be absorbed to stop the inaccuracies from being spread
  12. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I need to hit the dyno soon to update my numbers.
  13. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby it has this polish with it. I might try it to see how it turns out.
    webby likes this.
  14. webby
    webby Administrator
    50,617
    Yep, that looks good. It has UV protection stuff in the description, so give that a shot for sure.
  15. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby i think I made my headlights much worse :rotfl:
  16. webby
    webby Administrator
    50,617
    :oops: Uh oh. What’s going on?
  17. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I did something wrong. The first time I used my mini power drill(on low) to sand and it caused scorch marks. So on the second side I did it by hand all though it came out looking much better it still looks hazy.
  18. webby
    webby Administrator
    50,617
    Ah man that sucks. Well, I’m guessing it got too hot in one spot. Well, depending on how bad it is, you could save it by doing some wetsanding with some various grades of really fine sandpaper? You happen to have any stuff like 1000-2000 grit paper?
  19. mySIck
    1,830
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Yea I had some 1500 and 3000 I might try again tomorrow morning it was on the 90s when I tried so it might work better when it is cooler.
  20. bootyluvr
    • Supporting Member
    17,960
    Baltimore, MD
    Vehicle Model:
    Yeah.. chance is like .01% but better than nothing lol
Share This Page
