Mike's boosted build
Discussion in 'Build Threads' started by mySIck, Aug 20, 2015.
  1. mySIck
    • 2019 Toys For Tots
    mySIck Well-Known Member
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I got my Monster LED in. Some how USPS shipped them to my buddies house :hmmm?: and had to stop by after work to pick them up.
    A little side by side comparison to my old factory ones. I did take a pick of the dome light before but forgot the after :pat:.
    webby likes this.
  2. webby
    webby Administrator
    50,618
    looks like a huge difference on the reverse light brightness. Looks good
    mySIck likes this.
  3. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Thanks @webby it surely made a big difference all around. The factory ones were not bad at all but the LEDs did brighten up the inside quite a bit. I also did the trunk as well.
  4. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I got my hoses in. Once I get some time off from work I'll install it.
    ron v and webby like this.
  5. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I am a magnet for nails and road debris.
  6. webby
    webby Administrator
    50,618
    Freaking sucks. Did you find the nail to see if it can at least be repaired?
  7. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I did but it is time for new tires anyway. I am going to try and get an appointment tomorrow if I get time to get some Firehawk Indy 500.
    ron v likes this.
  8. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I added some LEDs to the Odyssey. Funny thing is it gives off some blue spots in the back.
    bauer311, ron v, webby and 1 other person like this.
  9. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby quick question, yesterday I replaced my License plate bulbs with LEDs tested worked out well. Moved on the the inner brake bulb when I tested them the left worked but I pulled the bulb out of the socket to check it and pushed it back in and turned off and back on my lights once I did that all me rear running lights have gone out. I checked the brakes and they work just no running lights.
    Do you happen to know the fuse they used and the location?
    I looked in the owner's manual and did not see it. I seen one that said running lights and it looked ok. Also my front lights still work.
  10. webby
    webby Administrator
    50,618
    someone else had a similar issue and they said fuse 34 in the cabin fuse box - driver side down by your left knee under the dash. Should be 7.5amp. A few said they changed theirs to 15 amp fuses
    mySIck likes this.
  11. webby
    webby Administrator
    50,618
    wait... are you talking about your civic or the van? I was referring to the civic ^
  12. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    The civic. I am going to try that one.
  13. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    Awesome that worked. Do you know how they labeled the right rear inner brake light?
  14. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    @webby my socket is bad. Thanks for the help.
  15. webby
    webby Administrator
    50,618
    sorry just got back on and saw your post. Hopefully you can find a replacement that works pretty easily? Did it get water in it, or do you see some sort of physical damage?
  16. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    It's all good I completely understand. I believe these LEDs will not work with the inner lights. I believe since it is a running light and brake light I need a different type of bulb. I put the factory bulbs in and replaced the fuse a 3rd time and they worked perfectly.
  17. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    I got my can put together and some what put on. I started late and trying to see where I want to put it. I am limited on space with intercooler pipes so i found in front of the battery to have a lot of space but I don't know how I like it there.
    ron v, webby and bootyluvr like this.
  18. mySIck
    1,832
    FT. Bragg, NC
    Vehicle Model:
    Civic SI
    Body Style:
    ron v, bootyluvr and webby like this.
  19. webby
    webby Administrator
    50,618
    :eyebrows:
    mySIck likes this.
  20. bootyluvr
    • Supporting Member
    bootyluvr Supporting Member
    17,961
    Baltimore, MD
    Vehicle Model:
    2015 Honda Accord EX-L V6
    :eek:
    mySIck likes this.
Share This Page
