Bulkybear
- 749
Bump
Yeah everything is set right. Polarity is correct. Sub is wired in parallel down to 1 ohm which my amp is stable at. Its definitely the signal I'm getting. Wired up my phone aux cable into the LOC and it played all frequencies I put to it. I'd bet yours is doing the same thing you just don't notice it. I'll bet if you play some bass mekanik on your radio then grap a friend with a aftermarket deck and grab his pre amp outputs you'll notice a very big difference in the way the sub reacts to the low notes.Man this is weird on whynthis is being a pain to u ?
Everything worked fine for me the first time around
Test that loc to make sure its workin fine but from wat i understand stock amps in cars are not crossover ajustable they would never do that because they know us owners would mess with it lol
Make sure ur 2ohm amp is set up right ok plus make sure the sub is dual vioce coiled with two speaker connections because if it does not have that it wont work @ 2ohms only 4ohms and wont be able to handle the amp @ 2ohms
And make sure - and + speaker wire on the amp is correct because amps these days are smart if they sence - and + speaker wires are reversed polarity the amp will auto shut off as a safety precaution so u wont blow a channel on the amp ...
Hope some of that helps in somway bro sorry ur going through this i hate when things dont go my way so i feel your pain .
