I have the funds and I have been ready. I have talked myself out of buying it so many times.
Just wondering what else I have to get besides the kit. Right now I know fuel rail. injectors. rbc manifold. some kinda Turbo timer. boost gauge. maybe fuel pump .flash pro. Clutch. And probably a lot more
List of items you will most likely need for a good 9thgen build: (I thought id make it easier for everyone to read and follow along, feel free to quote this post and add in your input/opinions)
- Hondata Flash Pro '12 Si
- Intake manifold should definitely be upgraded. Next step up from our plastic manifold is the Honda OEM RBC manifold (8th gen si manifold), next is the Honda RRC manifold, then comes all other aftermarket K series intake manifolds
- 3" Exhaust system
- K24z7 downpipe to mate with 3" Exhaust
- Intake (we'll see about this)
- Smaller battery ** free's up some engine space
- Throttle Body
- K series Fuel rail
- Injectors (possibly OEM RDX injectors to start 410cc, or higher)
- Upgraded Clutch
- Turbo timer
- boost gauge (pressure)
- Air/Fuel ratio gauge
- Oil temp/pressure gauge
- Fuel pump
With all this in mind (and feel free to add), you might want to improve the actual experience of your turbo build with things like:
- Short shifter assembly, (or just the short shift adapter for now)
- Shift knob
- shifter cable/base bushings
- Slotted/Drilled rotors
- new brake pads
- new rubber to grip the road, $$$ (which will most likely be accompanied by a set of new rims)
- suspension??
- sway bars
- Maybe a new front bumper. Im not sure if the intercooler fits without cutting or trimming the stock bumper. EVEN if its does, im sure you would want to open up your bumper or a secondary bumper to allow for more air flow
