Tools Needed:
Retaining clip remover tool or flat head screwdriver
Phillips head screwdriver
Allen wrench/Hex wrench
9/16 open end wrench
7/16 open end wrench
10mm deep well socket or standard socket with extension
12mm deep well socket
Cutters or snips
Hammer
Parts & Supplies Needed:
Base Bushings (optional)
Short Shift Adapter
LocTite
1. Remove the shift knob by pulling down on the shift boot. It will not simply pull straight down. I found it is best to pull down and angle it slightly and work it from there. You may find it easier to use a flathead screwdriver and pry the clip loose. Once the boot is off, use the 9/16 wrench on the retaining piece for the shift knob. Turn it right to loosen it. Once you have done this, you can turn the shift knob to the left. It will take about a dozen full turns to get it off.
2. Now you will need to remove the center console shifter cover by putting your finger down into the boot and grabbing the console and pulling it up. You will need to pull up the parking brake for clearance. I found that it came up with a modest amount of effort. Once it is loose, you will need to swing it left in order to clear the parking brake and remove it from the shifter itself. After this one is removed, you will need to pull the cup holders out. Just pull up on them. I found that this one stuck a little more than the first one. Just be patient and careful.
3. Now you will need to remove a bunch of screws and clips in order to completely remove the center console. There are two screws in the center console compartment underneath a mat and one connected to a metal supporting brace in front of the shifting mechanism on the right hand side. (There may be a second one on the left side of the brace. I do not have a clear picture and do not remember) There is also a screw in a metal bracket at the back of the shifter mechanism. There are additional clips in the driver’s and passenger’s side wheel wells—these are removed easiest with a retaining clip tool, but a flathead screwdriver can be used.
To be continued in the next post...
Cutters or snips
Hammer
Short Shift Adapter
LocTite
or you could be on the side of the road trying to get it tight again like what happen to me
