So I was driving down the free way and this guy in a pick up truck is cutting in and out of traffic. I can see him in my side view mirror so I brake to avoid this guy cutting me off ugly (which he does anyways) he speeds up and kicks all sorts of gravel up in front of me. SMACK I thought for sure my windshield was cracked. Got home inspected my windshield it was fine. But this was there!!! I almost cried gentlemen. My new baby is already getting destroyed. Anyone have any tips on what I should do??
Pull out a handgun and let him know you aren't happy??
Just kiddin. I wouldn't put that through your insurance, seek out a bodyshop that specializes in small damage repair. I would drive up to a few different shops to get quotes of this, most will do that in the parking lot in a few moments.
With today's UV cure primer surfacers ( cured and sandable in 90 seconds with intense UV lamps ) this repair should not cost over $ 125-150ish depending on your market. They will have to mix a small amount of the base color, and then clearcoat the entire top of the hood.
What they will need to do to repair: wash the car thoroughly, clean with wax and grease remover, sand back the damaged paint edge, possibly a thin coat of 2part putty, a light sanding of the area around the repair with P180, prime the area, then abrade the clear on the entire hood. This can be done in minutes with an orbital sander and P500. Once the primer is cured, block sand primer with P400, then sand with P500 ( solid colors ) or P600 ( light metallics )
This can be done with the hood on the car, or off on a stand. Once the hood is blown off, and cleaned with pre-paint solvent, then it can be wiped with a tack rag. 2-3 coats of the base color over the repair to hiding, blend out the basecolor and then clearcoat the entire hood. ( 2 coats )
