Mods, can you post everything typed below into my first post starting where I left off? Thanks.
3.14.2012
Looks like a no go for the cams and other cylinder head goodies. I received an email back from Marquis at KMOD Performance today stating somethings slightly different than I had been told before, but seeing as how he is the main guy I trust his advice and expertise. Here is what he said about building the Top End of the K24z7:
Sorry, but the 2012 Si Cylinder head & its parts are not interchangeable w/ the 02-11 K-series. Its an all new design. The cams, Rockers, Head bolt holes, are all different. The ex manifold is grafted into the head. Its really not an engine that can be modified for much over stock. Honda K-series modification stops w/ this one. There may be parts that come out for but don't expect large gains like the type we've seen w/ the 02-11 k-Series. It looks like forced induction may be the only option.
-Marquis"
So for now looks like simple bolt ons and ECU reflash will have to be relied upon to gain any additional power out of this engine. KMOD specializes in building K24 engines so this was definitely not something I wanted to hear but if I had to hear it, Im glad it came from a group of people who know these engines inside out. I have found out that Blueprintracing.com offers RBC Intake Mani Port & Polish for $500 or for $700 they will take a brand new RBC Intake Mani, Port & Polish then send it to you. The $200 obviously is the cost of the RBC IM. The RBC IM I ordered is on the way, still waiting for a tracking number though.
I have canceled the order placed for the 8th Gen K&N Typhoon Intake after some new light was shed on the topic of using an intake designed for the K20 engine on the K24. I am currently looking at AEM Short Ram Intakes designed for the TSX or Accord with K24s. Both vehicles take a different model number intake and from what I can tell is its the mounting points that make it slightly different, I don't mind having to fab some sort of new mounting bracket for the intake, gives me reason to get the welder out! I have confirmed that the Acura TSX uses an MAF identical to ours so the fittings on the intake should be correct (I am still looking for Acura TSX pics prior to 2008, but 2008+ seem to use the same shaped MAF). I will of course be checking with AEM in the next couple days when time permits with work and what not to see if I could use this intake system. I have seen several people using different types of intakes when doing K swaps, they usually find one that will fit the engine bay of whatever car they are swapping into and use it. More info to come.
I did hear back from Jeff Evan at Evan's Tuning concerning the Hondata Reflash for our cars, I asked him some questions concerning knock that I was getting in my 8th gen with Flashpro as well, here is what he had to say about it:
Kelly,
We offer the reflash option here: http://store.evans-tuning.com/tuning/ems/honda/hondata-reflash.html
The reflash is a pre set tune, so nothing can be changed. Further modifications other than what they have outlined in the reflash page could potentially lose power. Knock actually is able to be monitored even on the factory flash/stock through a dealer monitoring tool. Even the stock ecm seems knock while driving around, the ecu makes adjustments based on that information. I have sold alot of reflashes over the past few years and never had a single issue.
Jeff Evans
Evans Tuning
www.evans-tuning.com[/quote]
Sorry to reply to such a long post, but I want to clariy that the rockers ARE the same from a 2012 si and a 2011 accord ex k24. The cams would obviously have a different grind, and the intake cam gear is different because the vtc actuator is integrated into it. Valves are the exact same part number as well. I know you trust your boy, but he's misinformed. All performance parts made for the k series internals should go on just fine. Of course I would always double check against stock part numbers, but the only difference should be the integrated exhaust manifold being shitty.
