andre12dbsi
i want to put the stock ones back on after painting them. or do you mean the new stock ones?
Oh I see. I thought you meant the JDM ones. Yes, the stock ones will have pins.
not a bad idead but i think at that point depending on how much new emblems are might be worth it at last i know they will be straightIf you break the pins on the stock emblems and want to re-apply them you can do that with 3M mounting tape..... they have to be clean and dry, apply the tape, trim with a razor blade and then peel the backing and stick them in place.
Aligning them precisely will take a bit more work without pins, and once the adhesive touches, you won't be able to move them around. Best to place them without peeling the backing, mark the location with masking tape top, bottom and sides, then peel the tape to apply. The back will obviously be more difficult than aligning the front.
I'm not trying to save money I just would like to paint my emblems instead of the jdm. I still have mixed feelings about themTaking off the front bumper is ridiculously easy for one person to accomplish. To me it's more work applying tape, but if you're looking to save money then it might be the best option for you.
Yeah bro once you break the pins the only way is to use 3m tapeyes but how would you secure them back on once broken off?
