Completely Lost the Display on the iMid! HELP!!!
squiggy
Cartographer
VIP Member
11,331
6,756
Michiana
Toyota MR2 Spyder
Convertible
I was working on installing some speakers and the battery died on me. Can probably be attributed to music playing, headlights on due to always leaving them on auto (stupid me. I did this once before...), driver's door and trunk open, and the car was never running.
Anyway, I saw a warning (power steering I think) flash up on the iMid as I was checking preouts on the head unit and then the battery died about 15-30 seconds later. Jumped it. Started no problem, but no display on the iMid...
So, who knows what fuse to check for the iMid?
Also, does anybody think that unhooking the battery for 10-15 minutes to reset the ecu might do the trick?
I would try that and see what happens.... could be what the problem is. Unless you shorted out something checking pins, but I doubt it, if you were listening to music, with lights and other loads on, sounds like the battery voltage was low enough for it to kill everything. Charge up the battery and reconnect the wires.
That's a tough one, for me at least. Looked at the manual page 318 the fuses description and there is nothing about imid or display in general.
Here are all of them listed, sorry for the bad formatting :(
Engine compartment
■ Circuit protected and fuse rating
Circuit Protected Amps
1
EPS 70 A
ABS/VSA Motor 30 A
ABS/VSA FSR 30 A
Main Fuse 100 A
2
IG Main 50 A
Fuse Box Main 60 A
Fuse Box Main 2 60 A
Headlight Main 30 A
Rear Defogger 30 A
Blower 40 A
Sub Fan Motor 20 A
Main Fan Motor 20 A
3 − −
4 Left Headlight Low Beam 10 A
5 Starter DIAG, ST MG 7.5 A
6 Right Headlight Low Beam 10 A
7 − −
8 − −
9 − −
10 − −
11 Oil Level 7.5 A
12 Fog Lights* (20 A)
13 Driver’s Power Seat Sliding* (20 A)
14 Hazard 10 A
15 FI Sub 15 A
16 IG Coil 15 A
17 Stop 15 A
18 Horn 10 A
19 Premium Amp* (20 A)
20 INJ (15 A)
21 IGP 15 A
22 DBW 15 A
23 H/L LO 20 A
24
Driver’s Power Seat
Reclining* (20 A)
25 MG Clutch 7.5 A
26 − −
27 SMALL 20 A
28 Interior Lights 7.5 A
29 Backup 10 A
Interior
1 − −
2 ACG 15 A
3 SRS 10 A
4 Fuel Pump 15 A
5 Meter 7.5 A
6 Power Window 7.5 A
7 VB SOL* (15 A)
8 Door Lock Motor 2 (Unlock) 15 A
9 Door Lock Motor 1 (Unlock) 15 A
10 − −
11 Moonroof* (20 A)
12
Accessory Power Socket
(Center Console)* (15 A)
13 − −
14 Seat Heaters* (15 A)
15
Driver’s Door Lock Motor
(Unlock)* (10 A)
16 − −
17 − −
18 − −
19 ACC 7.5 A
20 ACC Key Lock 7.5 A
21 Daytime Running Lights 7.5 A
22 HAC 7.5 A
23 − −
24 ABS/VSA 7.5 A
25 − −
26 − −
27
(Front)
15 A
28 Washer 15 A
29 ODS 7.5 A
30
(Lock)* (10 A)
31 − −
32 Door Lock Motor 2 (Lock) 15 A
33 Door Lock Motor 1 (Lock) 15 A
34 Small Lights 7.5 A
35 Illumination 7.5 A
36 − −
37 − −
38 Left Headlight High Beam 10 A
39 Right Headlight High Beam 10 A
40 TPMS* (7.5 A)
41 Door Lock 20 A
42 Driver’s Power Window 20 A
43
Rear Passenger’s Side
Power Window
(20 A)
44
Front Passenger’s Side
Power Window
20 A
45
Rear Driver’s Side Power
Window
(20 A)
46 Wiper 30 A
Too bad not a single one says iMid.
Could the loud music have caused a vibration making one of your newly installed pins come loose? Hmmmmm? These pins are for the reverse camera though....would it even matter if one did? I would guess that only your reverse camera would to work, not the entire Imid screen. .????
Reverse camera goes into the Head Unit. Not the iMid.
Oh wow..... I didn't even know that was possible. Everyone i have seen add the reverse camera has it hooked up to te Imid. You must be one of the first... .???
It is a Pioneer with a dedicated input.
Yep. Looked at the schematic and it says the iMid runs off A19 for premium audio.
That doesn't make sense, though. I never lost audio.
On the other hand, I went out to lunch and the iMid is working again. :confuzzled:
alright well try swapping fuses... otherwise.. idk if fuse 19 was blown all accessories would be malfunctioning :(
