AlienPrime
Will finish when back in canada hahaha
I think it's going to be between HIDs and tires..altho i'm leaning toward tires just because i dont know much about HIDs and retrofitting and all that, i'd have to learn.
Thanks, i'll check out those tires for sure.
I already have flashpro
have an exhaust
and have a sedan lol
they are a EPST but dont stress about there tread wear rating
you can run a 235/40/17 on the stock wheel( i did no issues)
if youre looking for a summer tire or even anytime tire these things are amazing. they are predictable and soft...... everything about them is amazing.
maybe an intake? DP/tune?
retros are easy especially if you do the mini h1 cuase its almost like a plug and play as far as a retrofit goes. like webby said there will be multiple DIYs up soon so if you decide on that just buy everything and do reserach and by the time you have the confidence to do it there will be good DIYs available
edit: they came out with a newer version of the Star Specs(V2) but idk if they are out just search them
Dang.... you already did all the major stuff.... I like austins tire choice. Beastly 235/40 might be a bit overkill if you're NA still. Better tires are something you won't go wrong with no matter what. Either size, it's a nice tire.
The Konis are a nice upgrade also and will compliment most of your other mods as well.
I like the sedan front better actuallyHow about swapping to a coupe front end?
Lol thanks but I love my DBPHow about plastidipin' the whole car? You will have a few hundred left over.
Great, thanks. Tires might run me ~$450 so maybe I can do bothI just got out of the field so ill get my retrofit diy done up for you. I def recomend doing a retro fit. Prob my favorite mod I've done to my car. Plus after the retro fit you'd still have some money left for some other stuff. With highend equipment it would prob run you around $300, I did mine for just a tad over $100 and it still works great so its up to you on what you would want to do.
Let's see...How about a new horn?little yet easy
Then some #18awg wire to make independant fogs?
LED's and wire and put some trunk lighting + oem switches
Rear seat box swap!?
All these will cost under $100 in total![]()
