Just an update, I'm about 80% done with the install. It is FAR from a bolt on installation! Only 1 of the two bolts on the battery relocation bracket lines up on the frame rail. The clutch slave line/bracket needs to be unbolted from the gold colored bracket that is held onto the trans by two 12mm bolts that hold the case of the trans together. Then you will need to bend the hard line for the slave cylinder carefully so it will not interfere with the battery and the shifter arms. Then that gold bracket needs to be hit with a hammer to move it towards the passenger side or the battery will not drop into the bracket. The coolant reservoir hits the bracket also, I just unbolted the reservoir and moved it out of its bottom perch towards the frame rail then bolted it back in......this way it clears the battery holder and is still solid...easy enough. Then you have the ABS sensor wire, it goes along the frame rail where the battery bracket bolts against. I suppose you could just bolt the bracket on with the wire smashed in between the frame and the bracket but I took the wire harness loom apart and rerouted the wire. Getting the battery terminals to bolt on is pretty tricky also, you need to be very careful not to let the positive terminal touch against the battery bracket. I also had to take the wire looms apart a little to get the positive harness to reach. Just a lot of little annoying things. The upper radiator hose fits perfectly however! I will try to get a pic up sometime later. I started getting sick last night and I am really feeling it now.
EDIT: BTW, Webby I'm not going to post my dyno sheets due to the fact that Inline 4's dyno reads very low. When I went in for my first tune my baseline was 158whp & 138wtq. This was with full exhaust and intake. After flashpro tuning it went to 180whp & 164wtq. Now after the RBC/ZDX/Hybrid CAI I'm at 210whp & 172wtq....that's a 52whp/34wtq gain with simple bolts ons (minus the CAI haha). If I post dyno sheets it will just turn into a pointless thread about dyno numbers, different dyno types etc. Bubba at Inline 4 does an excellent job at tuning and I'm VERY happy with how the car is running now!
