Built By Notorious: 12' Silver Si Sedan; Project Wifey's Daily
Built By Notorious
42
19
Phoenix
Hello all!
We are Built By Notorious of Phoenix AZ. We are a import performance shop .. Here is my wife's project daily driver that we just picked up for her about a week or so ago.
And it begins...
BWR 8th Gen Civic 2" Drop Springs
BWR Aluminum Red Lug Extended Nuts, BWR Short Shift Adapter from 8th Gen Civic, 9005 3k Yellow Running Light Bulbs, Honda OEM 8th Gen Civic rear upper coil spring isolators
Awesome. I'm looking forward to the build.
BWR drop spring installed in the front.
Fresh off the lift.
Before and after.
Rear settling after 1st test drive!
More to come... Still have to Install a few parts I have already stock piled.. Lol
Next up
9006 Hid Kit 6k low beam
9005 Halogen 3k Yellow Daytime running / Hi Beam
1 x 12" Rockford Fosgate p1 Sub w/ 500 Watt amp
Rear View Camera Hack
Mid muffler delete
Intake Resonator delete with K&N drop in filter
(Intake and exhaust mods will be temporary till we decide if we are turbon' it or not)
Hey good to see you on here. I used to be on AZHT a lot when I had my ej8. Cars looking good so far!
Need anything special to install those 8th gen springs on? Cause damn that's a low *** drop if it is 2 inches lol
Just the rear upper spring perches from an 8th gen., 2" drop was for an 8th gen also. I think it's closer to 2.5 front tho on our 9th. Rides nice and handles a little better. Will do the job till I can justify K Sport money after some more mods.
Damn that's pretty low for springs, I'm assuming you needed camber kits?
Just my two cents, sportlines springs from eibach are made for the 9th and offer about the same drop
Correct they are a touch higher in the rear. I'm ok with it for now. Can't complain for a drop spring that retails at half of the cost of Ebiach and only temporary.
true and i wasnt saying for you, for Jonathong if you dont want to mess with the 8th gen rear isolators
Got a couple more parts in for wifey's Si!
Spec D: Rear camber arms 06-13 Civic
Eibach: Front camber bolts
K&N: Drop in air filter
Need to make time to put these on, get it an alignment.
How much for those rear camber arms? You gotta let me know how they fit.
