Safety first! I liked the two jacks!That tire. lol.
Okay...I just learned something.
But the HFP kit uses the stock knuckles...tried them today... think the HFP suspension is the problem.. these are not standard... even the mechanic i had with me said so....
so you'd think it would be the same as the si.. but i has no spots for the "tab" to slot in and the bolt itself just spins freely inside and doesn't change the camber at all!But the HFP kit uses the stock knuckles...
Anyone know what the size is for a 2013 non-si?
OH NOOOOOOOOOOOO!!!!!! That little tab off the washer MUST sit down in the hole. Do not tighten it without that tab in the hole... when you spin the washer, it changes camber too (like the bolt).
Si is 16mm. EX/LX is 14mm. On the 8thGen Civic (06-11), all are 14mm including the Si.
Chris
Are you sure? I just emailed the guys at SPC and Eibach. They both said a 16mm though..
