- 55,554
- 23,822
what happened?
what happened?
jbweld the hole... then drill?
Welding is the plan. Just have to find someone to do it. I think my neighbor or his son would be able to.
Jbweld is an excellent product, I used it to fill in a crack in my oil pan and it worked great. All through the winter it held up and still doesn't leak anymoreHmmm...just looked into what the "jb" part of that was. Interesting. That sounds like a plan!
and how important is it to torque the endlinks to the proper specs. Pretty sure mine are torqued higher than 28 lb ft.
The goal is to swap all the lighting out with red if possible. I have already done the ambient light switch and VSA switch.i'm sure a very thin piece of red vinyl will work, maybe make the lights a little more dim but it'll look good.
the moonroof button looks great btw
That looks good but they are super bright lolView attachment 18613
Swapped out the bulb in the moon roof switch.
I started out tearing apart the temp controls to see how the lighting worked in there. I am going to have to buy one from a junkyard to play around with it.
Or maybe I can cover them with red vinyl?
Going to tackle the steering wheel next to see if a bulb swap is easy or not. (CollegeHillsHonda Why do the torx bolts need replaced once the airbag is taken out?)
You'll love this mod! I know I do.Ordered some horn replacements.
I used to be ashamed to lock my car when I got out and heard that little squeak that Honda calls a horn.
Which ones did you get?
Same as mine! NiceThe FIAMM ones off of Amazon.
