THECLARKSTER
Member
- 2
- 0
Hey man Thanks for the reply! Is there a way of finding out the member he bought them from originally? Appericate the info- first time on the site.
Where did the plugs that connect to the headlight come from? I have the ones specified in the materials but that isn't enough to create the harness...
http://www.collegehillshondaparts.c...-28-8w/33303-tr0-a01?search_str=33303-TR0-A01
2 of those ^
jason - check your link in the 1st post for those plugs. I'm guessing you wanted it to be that ^ ?
That's what I'm trying to do but where do I get theseYou make your own harness if you didn't get one. He has the diagram in post 3.
	Isn't that what this is?That should be the plug from post 45 I linked you to.
	--Wire Splicing--
If you do not have a plug-n-play harness/adapter, then you can splice/solder the wires from your existing OEM turn-signal harness to the two new harnesses that come with the projectors. Here's how to do it:
- You need to open the loom behind the stock turn signal socket to expose the 3 wires:
(1x black=ground, 1x blue=turn signals and 1x red=parking lights)- Use either splice connectors or simple soldering to connect the two red wires (parking light) from the new headlights to the black wire and red wire from the stock harness.
- Use either splice connectors or simple soldering to connect the two yellow wires (turn signal) from the new headlights to black wire and blue wire. If the yellow wires are too short, you will need to buy 20-gauge wires to extend them.
	Yep. I'll hunt down the plugs and and if not just find some pin connectors to jam on for now.Bunch of people bought these lights on eBay without a harness.
...but...but they're useless without the harnesses. My god.Bunch of people bought these lights on eBay without a harness.
