hotshot
- 314
I'll do it tonight.
The hot spots and output will look that way with a HID bulb. The curvature and design of the reflector bowl is designed for a halogen bulb. I'm sure a halogen bulb will look better than the other pic shown above.
	No, it's a TSX-R lens. Definitely 2.5".
As a matter of fact, you really don't have to buy lenses. It's kinda personal preference. To be honest, Id probably sell the clear glass lenses if I didnt have one projector installed already.
This is the same setup with the fresnel lenses from the TL projectors:
The lenses from the civic projectors are the exact same.
Yeah, the Lens clips into the black plastic holder and then the black plastic holder clips onto the reflector bowl, with the metal shield sandwiched in the middle.So are you saying the lens and the projector are independent of each other? When you install it into the headlight housing, do u first have to clip it onto the projector first? Or just install it onto the black plastic thing that u showed us before. Thanks for taking the time to answer...
You don't want those projectors unless you want to do some cutting and drilling. Tell TRS what you're doing and that you want 4G TL projectors. They are a direct swap.
hotshot...Another quick question. How does your blinkers look after installing your harness? Does the corner and inner lights alternate or does the outer/corner light stay on and only the inner light blink?
I haven't wired them up yet, but my inner lights will only be on when it blinks. I don't like the wig wag look, and I don't think it came that way from the factory. I'm gonna try to get it on this weekend.
How did u take out the oem projectors? The space is so small, all I can manage to take out is the shield. Any tips?
