Wow. Very interesting. I have been running my Koni's at 1 1/2 turns up from full soft.
Quick summary of a very long upcoming post : I think that either 1/2 turn or 1 full turn would be ideal for most people.
I'll list my full setup and let you guys extrapolate from there:
Car: 2008 Civic LX
Tires: 225/45/17 Dunlop Direzza DZ101 ( I do not recommend this tire, but that's for another thread)
Suspension: Koni Yellows with Neuspeed Sport Springs
Spring Rates: 218 Front / 448 Rear
1 set SPC front Camber Bolts
Skunk2 Rear Camber Arms
Performance Alignment: -1.3 Front & -0.8 Rear
(Alignment will affect handling as much as anything else)
Tweaks: Progress 22mm rear sway, Moog endlinks, Energy Sway Bar Bushings
Serious Tweak: Upgraded Front Lower Control Arm Bushing. Basically a traction ball. I can tell you nothing about this.
Stock Part on Left & Upgrade on Right
16.3116
In any case....
I have felt that the 1 1/2 turns is very very stiff for DD use. So stiff that the whole car seems to bang over bumps. I thought the rears were too stiff at this setting but I have been getting used to it. I still get understeer when the road is slightly wet. Certainly the tires break free easier but I feel like the wet conditions simply show what the car will do without having to push the speed to break free on dry roads. That said I get oversteer in the snow. Go figure that one out.The 8th gen to 9th gen have very similar suspension so I expect results should be very similar for everyone.
I would definitely recommend everyone start at full soft and slowly increase the stiffness. I have left mine alone because I love the way the car generally feels going over dips and curves. It is stuck to the road. But.... Bumps suck! That is certain. I get a headache from my car on long trips if the roads are bad. I live in upstate NY so they are horrid. That said 1:45 drive between Rochester and Syracuse = Heachache
I recently drove 10hrs from Rochester NY to Lousiville KY. The roads were definitely improved further south and I did not find the ride to be unpleasant. So do keep road conditions in mind depending on how much you drive.
