Arm0ged0n
You need to have an RBC manifold swap with 8th gen Injectors though, unless you have that swap? Any word on the PM I sent you last night?I want one.
Thanks manWell damn. They need to make a fuel rail for the 9th injectors to go with the p2r im runners which will be going on mycar as soon as i get off the couch. My buddy is looking around, its not something he usually stock so hes having to look around.
All I have to say is HOLY &@&@! That car has to be bad azz, what kind of hp and times at the track did you do,you got pics of his ride?While its not a 9th gen, this is how crazy the mod bug (and repairs) has gotten for my 2007 FG2:
35.00 - 2nd OEM Shift Knob
165.00 - Suede XLR8 Gauge Pod
145.00 - Omni Clutch Master Cylinder
185.00 - OEM 07' FG2 Fog Lights
300.00 - PLX SM-AFR Wideband & DM-100 OLED Gauge
74.89 - Hybrid Racing Shifter Bushings
339.80 - TWM Stage 2 Shift Assembly w/ Red Stitch leather shift boot + Base Bushings
46.95 - Clutch Slave Cylinder speed bleeder, Brake bleeder (x4)
382.00 - CC Stage 2
329.00 - Innovative 60A motor mounts
224.10 - CC Lightweight Flywheel
38.94 - Russell SS Clutch line
3540.00 - CT-Engineering Supercharger w/ 3.6" pulley, 3.15" pulley, FlashPro, 520cc injectors, etc.
307.54 - CT-E idler pulley, belt, a/c spacer, a/c bracket, etc.
85.00 - 2nd idler
20.00 - 2nd tensioner
55.99 - Magnetic Oil Filter Collar
1145 - Go-Power Custom Header (Coated)
650 - Full Race 3" exhaust
30 - Skunk2 oil cap
284.05 - PLX SM-VAC/BOOST + DM-100
28.69 - Blox trans/crankcase bolts
69 - Weathertec visors
16 - Red steering wheel H
105 - Walbro GSS342
300.80 - AEM CAI 21-685
38.23 - AEM pre-filter
1200 - HFP lips
140.25 - Hotchkis endlinks
24.67 - CT-E boost fitting
585 - RPF1s & Hoosier radials
2400 - Advan RZ (shipped)
~750 - 245/35/18 Hankook K110's
130 - Advan Center Caps
107.90 - McGard Lugs
150.85 - Exhaust shielding
62.52 - Catch cans + misc fittings
300 - tune @ RLZ
200 - tune by Vit
44.81 - OEM t/o bearing
252.69 - new OEM steering wheel + other misc.
159 - Progress rear sway
75 - Blox front sway
270 - Skunk2 camber arms
20 - Replacement camber arm joint
59.51 - ingalls camber bolts
60 - 5mm wheel spacers
42.25 - GRFXP order
38.00 - another GRFXP order
40 - Tail overlays
246 - GoPro HD
42.77 - GoPro HD acc.
125.00 - Helm 8th Gen Honda Service Manual (Vol 1 & 2)
1500 - 2nd countershaft, 2nd mainshaft, & 2nd second gear (Bro hook-up @ Honda)
3895 - Albins mainshaft, countershaft, 3.00 1st gear, 2.00 2nd gear, and 4.77 Final
425 - Wilwood BBK and other goodies
450 - CM FX400
250 - Toda timing chain tensioner
100 - Hasport FDRR mount
900 - Go-Power Coilovers
100 - 1st replacement clutch bracket
100 - 2nd replacement clutch bracket
100 - 3rd replacement clutch bracket
90 - OEM all season mats
85 - Trunk tray
200 - Optima YellowTop
1125 - MercRacing Stg 2 Aftercooler
300 - ARC DC2 splitters
170 - 3rd & 4th idler
460 - ID725cc injectors & PnP clips
175 - HID/Projector retrofit project parts
40 - 3rd OEM replacement shift knob
100 - ROP valve cover
175 - EM1 CMC w/ Hybrid clutch line
~600 - Firewall repair (Originating from old Competition Stage 2)
375 - ClutchMasters FX300 (Assumed faulty; turned out not to be - sitting on it for now)
390 - ClutchMasters FX400
260 - Full Race spherical LCA bushings
140 - Hawk HT-10s / F pair
72 - Hawk HP+ / R pair
~775 - 245/35/18 Continental DW's
120 - Goodridge braided brake lines
75 - Centric 120 rear rotors
110 - StopTech Street pads (both axles)
120 - Brembo blank front rotors
640 - Acura TSX front calipers
180 - Acura TL Type S brake master cylinder
42 - ATE SuperBlue brake fluid
100 - Replacement Hasport FDRR 88A mount
400 - Replacement Innovative billet 88A mounts
48 - Moog replacement front endlinks
Total:
31654.20
. When i turn 25 (4 more years) civic will get stored and i'll take my flight to japan to grab myself an '99 R34 GTR Spec V Nur II. then, only then will true modding start
I'm not sure about you guys, but spending $90k on a car like that, and then being able to beat an enzo on a highway pull... that's worth all the month in the world to me
i knowwwYou got a good deal on those Advans. Nice.
Advans FTW!
Most sites have them listed for $2900+ for the set of 4
Over $6000 as of friday after purchasing advan rs's
Total = $6380
- lighting (hid's, led's projector lenses etc) $300
- emblems $110
- professionally painted calipers $200
- tint $180
- decals badges and all other misc shitt $150 (including alienprime logo's etc)
- custom plates $275
- domes/new lenses/paint/led's $100
- extra headlights to remove amber $310 (both)
- ez-lip sides/front $90
- advan rs $2300
- volk rays valve stems $90
- camber bolts $80
- camber arms $300
- blox forged lug nuts $100
- eibach springs $200
- all interior LED's/underglow/wiring/and ALL misc electrical +$300
(i'm positive it's more {$230 just for bussman fuses and Schneider relays})- powerwindow module $80
- engine bay H7 temp sensors and readout LCD screen red led $170
- Black pillars $50
- Mugen cf mirror $95
- jdm hazard $50
- wiring harness for mic in trunk $50 (for GoPro)
- fenderwashers/hardware $100
- HKS intercooler rad cap $40
- G9-Series Contactor for custom fusebox relay setup $260
- Paints etc for valve cover/fuse box etc etc $50
- tsudo catback $350
probably forgot a lot.. well little thing, battery tie downs, ect etc idk i don't feel like looking through everything haha just off the top of my head lol.. also guaranteed i spend more than $150 on decals lololol
Will be more after tires. That's not including the $7600 i spent on Brembo superturismo brakes when i first got the car and everyone laughed at me for thinking they would fit.... still haven't sold those btw but still at my buddies house
Might try and snatch them back and try them under the advan's
and for those that ask why you don't go other cars, don't forget about insurance costs. When shopping for a new car, i had two cars in mind. 2010 40th anv. z34 nismo and a 1992 nissan pular gti-r
z34 was like 950/month payments, with about 930/month insurance, gti-r was like $1800 + $1660/month for insurance lol.
so i realized i needed an econo car to get rates down... civic is it.. fwd 4cylinder, so i walked into the dealer and told him to get the baddest sexiest, rarest 2 door civic he could.. hfp it was. When i turn 25 (4 more years) civic will get stored and i'll take my flight to japan to grab myself an '99 R34 GTR Spec V Nur II. then, only then will true modding start
lol you can't add car paymentsssss lololol2012 rr Honda civic
Tint 200
Foglight tint 10
Hids 60 for 2 sets
3k high beam bulbs 8
3k fog light bulbs 8
Carbon fiber hood wrap 100
Tsudo exhaust 400
Skunk 2 springs 200
2 sets extended lug nuts 160
Stickers 50
Xxr 527s gold 725
Achilles 215/45/17s 530
Xxr 526s gloss black 815
General 205/40/17s 400
Mounting and balancing 3 times lol 450
BC racing coilovers 1080
Alpine type R 12 with spec box 20
Alpine Mrx55 amp 250
Wires 40
Car payments so far 6300
And more to come lol
gimme some time bro! Things will come together
Haha whoopslol you can't add car paymentsssss lololol
