Pauly99to17
So, there's a local guy selling his 22 mm Progress sway bar. He has an 8th Gen sedan. Would this sway bar fit my 9th Gen sedan? Something tells me the answer is no.
YES. It will. @FB2Chris has the 22mm on his car.
Okay, thanks. So what all should I be asking is included? ( I have no experience with sway bars.)
If the seller isn't including a set of Si brackets, you'll need those in order to bolt the bottom of the bushings on.
1) Sway bar
2) Si brackets (Si? Why Si? Shouldn't it be Progress bushings?)
3) ?
4) ?
So... if brackets are not included, just follow the directions in REDOther than the sway bar itself, nothing else is required. Unless you want the reinforcement brackets which require drilling; they just add rigidity.
Wow. Thanks for the footwork. The diagram is really helpful.
How do you like this sway bar?
What would say would be a good price for me to pay for a used one, probably for just the bar. I will need to order the rest of the parts.
Thanks for info guys. I offered him $ 100, but am ready to go to $125.00. We'll see what happens.
BTW... He said it would come with parts #10 (a little hidden in picture) and #11.
Would I need to order other parts?
When I take my sway bar off, I would imagine I could use the same bolts. ??? (#37 in diagram.)
He's at $140.00 plus i would have to Pay 25$ to havé it shipped from Montréal.
Yeah i think thats still a little too high. That makes it in the same range as a new oneHe's at $140.00 plus i would have to Pay 25$ to havé it shipped from Montréal.
Which vendor? Thanks.new ones can be found from vendors around ~$170.
one example (price shipped in the US). I'd pm for a quoteWhich vendor? Thanks.
