Squiggy's 2012 DBP II Si Coupe
It's easy. I can do a DIY for you right now!
Step 1. jack up car. Put car on jack stands
Step 2. Remove top dog bone mount
Step 3. Remove the bolt from the front motor mount.
Step 4 remove rear mount ( will have to rock the motor slightly to release it. Very easy)
Step 5. Rock motor forward ( meaning pushing the oil pan towards the front of the car and the valve cover towards the rear of car and that should give you the clearance you need to slide the rear mount in. The motor will be supported by the to side mounts knows as the driver and passenger mounts! Which will give you the rock movement. )
Step 6. Install the front mount bolt and tighten slightly.
Step 7. Install the top dog bone and tighten.
Step 8. Tighten font mount bolt.
Step 9. Check all mount and make sure everything is tighten.
Step 10. Put car on ground and enjoy your no more wheel hop!
I think that is about it. :rotfl:
i need pictures :)
Instructions are great, but it is the pictures that make it a DIY!
One of my Nokya yellow fog lights went out today. :(
so it may pay to go yellow vinyl instead of yellow bulbs if they have such a short lifespan
