RedRocket_Si13
Active Member
MOD DIFFICULTY 1/10
LED LICENSE AND REVERSE LIGHTS
What I used:
Flat head (for the trunk carpet clips)
Philips screw driver (for middle screw on trunk carpet)
(4) zone tech 8smd T-10 168,194,2825 w5w white(comes in a pack of 8 so I used the rest for the map & done light
Lastly your hands
First you have to un clip these clips 2 on each side
then the Phillis screw in the middle
then you want to move that carpet out your way and unclip these wire clips on both side
TADA!!
then you have the bulb housing you want to pinch both sides like so
take out the old bulb and replace with led bulb
then just clip everything back on the same way
While you have that carpet down might as well do you reverse light which are just as easy
Unclip the wire
and turn the bulb housing clockwise towards yourself and pull down like so
then take off your old bulb insert the lED, insert the housing back in the hole and turn counter clock wise and insert cable again then just do the other side the same way
What I used:
Lastly your hands
	TADA!!
Unclip the wire
