- 24,335
With more power, a lighter chassis and stiffer suspension, the next-generation Si is ready to rule.
More Muscle
Under the hood for 2012 is a 2.4-liter, 16-valve, DOHC i-VTEC® engine that produces 201 horsepower and 170 lb-ft of torque. That's a 22 percent increase in torque over the previous generation of Si engines.
Less Weight
Weight-saving technologies and improved aerodynamics result in a new Si that's leaner and meaner. And because it's a Civic, it still gets an impressive 22 city/31 highway mpg[1].
Shift into Awesome
The smooth-shifting 6-speed manual transmission is perfectly paired with the Si's helical limited-slip differential for the utmost in handling and control.
The Si's instrument panel is home to a new, improved Sequential rev-limit indicator. Instead of a single shift light, a series of six sequential lights indicate rising engine speed. And when you get into the right rev range, a bright i-VTEC®light is your reward.
[1] 22 city/31 hwy/25 combined mpg. Based on 2012 EPA mileage estimates.
