For those who are unsure of safe places to jack your car up and places to put jack stands, I decided to take some pics and put it in DIY for reference.
JACK POINTS
On each side of your car below the doors and near each wheel well is a piece of steel that sticks down just a bit further than the rest of the side skirt.
These are the ONLY places you should be putting a jack or jack stand on the side skirts!
The following is what will happen if you do not heed the warnings:
In the front, underneath the bumper, there is a place for a jack on the frame also. There is actually an arrow pointing to where to place the jack. Oddly, the arrow looks as if it points to a smooth place just off center. The spot I have used on my civics actually has a bit of a lip coming down and I use it as a catch for the plate on the jack. This is just to the right of where the arrow is pointing in the picture (perspective may vary when/if you are under the car) . As you may notice, it has been bent in a little bit. Not a big deal.
There is no known place to use the jack on the rear end of the car.
The tow hook is NOT advisable due to stability issues!!!
JACK STAND PLACEMENT
If you are using the jack point under the front bumper, you can use the jack point towards the front wheel well for jack stand placement.
If you jack the car up from one of the rear points, you may be wondering where to put the jack stands because there is no jack point under the rear bumper. My only solution was to put the jack stands under the control arms. Unfortunately, this means jacking up the rear one side at a time.
Conversely, you could jack the car up from the control arm and then put the jack stands under the rear jack points depending on what you need access to. I will sometimes put my stands under the front control arms depending on the situation.
If anybody else has any input, please feel free to contribute.
JACK POINTS
