K24seven
So, who sells these for the best price?
Tire Rack $215.00 Shipped. Anyone price match or beat it???
http://www.tirerack.com/suspension/...odel=Civic+Coupe&autoYear=2013&autoModClar=SI
I ended up getting Eibach Pro Kit springs. Thanks though.Tire Rack $215.00 Shipped. Anyone price match or beat it???
http://www.tirerack.com/suspension/suspension.jsp?make=H&R&model=Sport Spring Set&group=Sport Spring Set&partNum=51891&autoMake=Honda&autoModel=Civic Coupe&autoYear=2013&autoModClar=SI
Really like them. I don't think you can go wrong either way.Sweet! How do you like em? Those are on my shortlist btw. Can't seem to make up my mind.
i understand that toe would need to be 0 for tire saving, but how about camber, whats the best and safe number to have?
Camber can greatly effect how the car handles so you have to decide weather you drive aggressively enough to warrant a performance alignment or if the stock numbers are best.
There is no "safest" number although the stock settings will be the most familiar feeling. You can always get the arms if you decide you have too much neg camber in the rear or if you need them to gain camber to fit your wheels.
Personally, I think the factory settings are not that great. Run less negative camber and more front for a better handling car and to help eliminate some of the understeer that comes built in from Honda. I'm running -0.8 R and -1.2 F with as close to 0 toe as possible.
Is that enough to eat through tires ?Camber can greatly effect how the car handles so you have to decide weather you drive aggressively enough to warrant a performance alignment or if the stock numbers are best.
