Dennis Rockholt
9k Alll Day
I checked and havent noticed anything...Ill be looking at it tomorrow and making sure its just the vibration. I checked the bolts and pipe earlier this week and the mounting is fine. It hardly moves when I grab onto it.
what a pain
For everyone that used jackstands, how did u get these bolts off??Lol! Breaker bar?
Patience, PB Blaster, breaker bar, impact wrench. Make sure to use a 6 point socket and not a 12 point.
Well i sprayed the **** out of it with pb spray but still wouldnt budge so i just pulled the entire exhaust out.
Its got a little bit of rattling issue that i have to fix this tuesday.. took me longer than its supposed to but i love the outcome! Skunk2 exhaust/dp
I have to look and see.. someone told me its common with the rear heatshield and the stud in the midpipe
interesting to me.You absolutely have to take off the windshield wipers to install ANY downpipe on a 9th gen Si.
interesting to me.
i took my valve cover off and put it back on, i didn't take the wipers off... i don't see how the dp would magically make the wipers need to come off.
what i am getting at, is i took off the entire cowl (plastic and metal ) without taking off the wipers, and that gave me enough space to take the entire valve cover off.What? If you try the install then you will see. The heatshield above the downpipe bolt point blocks any access to it, and to get to the downpipe, you have to remove the wipers and plastic to get that heatshield off. Other wise it would require some sort of magic to get to.
You need the clearance to be abe to to take the O2 sensor out as well as get to all four bolts that point towards the fire wall. If happen to have tiny little baby hands/forearms and can manage this without taking to cowl off, more power to you.what i am getting at, is i took off the entire cowl (plastic and metal ) without taking off the wipers, and that gave me enough space to take the entire valve cover off.
If there is enough space to get the valve cover off, how is it not enough space to work on the DP?
my argument isn't if the cowl has to come off..... my argument is the fact you claim the wipers do. when in fact they do not.You need the clearance to be abe to to take the O2 sensor out as well as get to all four bolts that point towards the fire wall. If happen to have tiny little baby hands/forearms and can manage this without taking to cowl off, more power to you.
I know the cowl needs to come off. my point is why do the wipers have to? you can remove the cowl without removing the wipers.
are the wipers really in the way of the dp after the cowl is removed?
You are wrong.The cowl has to come off completely in order to create the room/clearance needed to access everything and be able to turn a wrench. So, YES, the wipers have to be taken off. Even then, it was a tight space to be working in.
