- 56,710
- 24,142
jrotax said that the front is not needed. He advised going with just the rear for better handling
first off, great writeup! nice pics, definitely a good in depth DIY! props on the part (i want it b/c the color matches my ROP sedan haha)
my once concern though is, not sure if this is the same on the civic or not, but on my WRX i was required to install the rear sway with a load on the suspension (as in, i could install everything but not tighten the brackets/endlinks, then i had to lower to the ground to load the suspension and crawl under to tighten the bolts)
i'm wondering if this is the same on the civics for a proper install?
ps. noted WRX in the background , props to that too ; )
I tried getting the old sway bar out without removing the brace that's under the gas tank, and couldn't do it.
In retrospect, it would have been worth it to buy a pair of upgraded end links, just to have less rusty threads.
It comes with reinforcing plates, and the option to drill a second hole in the mounting plate for a second bolt. I was planning to do that, but my drill is too long to fit the space needed to drill in the proper direction. So, no second bolt.
Should car be under load when doing this?
