mr_guitar3825
Member
My flash pro comes in today. I is there a preloaded tune that will be better than stock?
DO NOT attempt to modify settings if you do not have experience doing so. Pay someone experienced to do it.Where should I set the launch limiter at? What's a good set up for the vtech window?
He'll give you a base map right away. I never bothered going farther than that until I was ready to dyno tune it.
Ohhh **** I put mine at 4750 just so I could hear it engage better, the stock setting at 5000 I couldn't hear the shift like at all. I don't think that'll be to bad would it?Oh also, no big deal to change your own launch RPM. Don't mess with the VTEC points unless you really know what you're doing. You can royally mess up your motor if you set it too low.
Yea I left all that alone il let vitviper handle all that once I get my DP to get it tuned.@Scornio - I doubt that small change would be much of an issue and that's definitely not too low... Hondata has info about tuning on their site, but unless you really know what you're doing, I wouldn't mess with much more than simple settings like launch window, speed governor, rev limit, etc. VTEC engagement at too low am RPM can damage an engine. Improper timing and fuel metering can likewise damage things.
