It was 10:30 by the time I finished the fronts. I get up at 6am...The rear springs only take a few minutes each! You could've done it.
Pish posh. You stay in the garage until you get so frustrated that you throw a wrench at the wall. Only then will you have a true bond with your carIt was 10:30 by the time I finished the fronts. I get up at 6am...
Unfortunately, yes still the stock all seasons. They will probably be nearly toast after The Dragon. I plan on getting new wheels and tires in the spring. Not in the budget right now...especially since I will be buying a winter setup soon.What tires are you rolling on? Don't tell me it's still on the OE Michelin MXXMXMXMXXMXMXXMX4s, They won't be happy come dragon time.
There is enough tread left right now. Car only has 18.5k miles on it, but I am a bit rough on the tires. Worst case scenario is they will be down to the replacement indicator lines once the weekend is over. I may catch a lift for a few runs though. I am still one of the slow ones...Ehhh...there's a lot more driving compared to last year, if you want you can ride along with any open-seaters on the Friday / Saturday drives if you don't want to totally annihilate your tires. I drove back to PA two years ago on 2/32" and it wasn't fun.
Mine werent earlier this spring when I did that....those tires were complete garbage
I don't dispute that. I had no problems getting the rear to swing out on some of the turns last year. My plan is to destroy them at The Dragon and then put winter tires on the wheels a few weeks later. I will buy new wheels and tires in the spring.
Nice, car looks great btw.
Thank you! I can't wait to round out the exterior and finish the retrofit, get new wheels, and get a BBK. Gotta put the front HFP lip kit on too.
I can't wait for my all seasons to be destroyed.I don't dispute that. I had no problems getting the rear to swing out on some of the turns last year. My plan is to destroy them at The Dragon and then put winter tires on the wheels a few weeks later. I will buy new wheels and tires in the spring.
You should be rotating them once a month at that rate!My tires are pretty much gone too at 16k. It's been hard to NOT spin them just trying to take off somewhat calmly from a light or something.
